2001 Raptor 660---- HELP Please (PROBLAM FIXED)
Old 01-30-2008, 07:04 PM
MYRAPTORBITES's Avatar
Default 2001 Raptor 660---- HELP Please (PROBLAM FIXED)
2001 YFM660R.. The ground was loose and I burnt up the wire harness. I replaced it and the bike is burning very rich when you give it gas it back fires and it's very hesitant but idles fine. I removed the carb and cleaned it dumped the gas and cleaned the tank and still, same problem. I replaced the carb still same problem, I adjusted the valves and replaced the CDI With a Big Guns High Rev. now it backfires more and louder.. does anyone have a clue??? [img]i/expressions/face-icon-small-blush.gif[/img](
Old 01-31-2008, 09:34 AM
fastraptorman59's Avatar
check your parking brake switch.If it gets stuck,it will miss and is un rideable...
Old 01-31-2008, 11:52 AM
I failed to mention unpluged the parking brake from the wire harness
Old 01-31-2008, 07:55 PM
Problam fixed.. bad contacts in wire harness.
Yippie [img]i/expressions/face-icon-small-blush.gif[/img])
suzukiquadrunner1987
08-09-2015 08:45 PM
GNorm
08-01-2015 11:06 AM
black_thunder
07-26-2015 09:23 PM
black_thunder
07-22-2015 06:01 PM
Dirtbikemike1
07-11-2015 03:36 PM
Quick Reply: 2001 Raptor 660---- HELP Please (PROBLAM FIXED)
