Top end warrior rebuild
Ok so im ordering the kit on wed to rebuild my warrior!!! spent the weekend getting my shop and tools in order and doing research. Seems to me the main point of concern while rebuilding the top end is ensuring that your timing is correct and that your motor sprocket and rear sprocket are alligned. I dont want to tear back into it once its back together (although i will if i have too!!) to correct something that should have been done right the first time.
You are right on with making sure your timing is right, but the sprockets don't have to be in any order alignment as far as tooth wise, and should still be striaght in geometric alignment since your not removing any of the rear axel. Or did you pull ur whole motor?
easy, except the head bolts on the warrior are a Bi*** to get out, once they clear lean the head forward and take them throught the front of the frame in between the wiring harnesses. I wouldn't recomend taking the motor out for a top end job, to much work. Its not hard, just make sure you have all the parts when you go to do it, or it will get aggrivating, having to leave it sitting in peices, then finding the time to get back to it
there are alot of pro's, and alot of diffrent opinions on cams, me personally I'd go with the hotcam as it will go right in without heavy duty valve springs or any head work for that matter, though I would recomend getting new the head checked out to make sure the guides, seats, and valves themselves are ok.
The con is you have a 1988 warrior, proabably with lots of hours and wear on it... If you leave the stock cam in there, that is proabably worn out, you will loose some of the HP gian you will get from the top end rebuild, atleast put in a new stock cam, thought I don't suggest it, and it proabably cost more than a hot cam. Maybe not.
Now people will get on here and tell you to buy a webcam, they are great cams, however they do require heavy duty springs, which are a pain in the *** to put in, which require some clearance work, so you would have to have a shop do it, and there is another $200 off the bat. Plus it makes the warrior, which already has issues, harder to start, inturn less reliable.
Hope all that made since.
well if i were to do it, it would be with a stock cam, like you said its an 88...i want it to be reliable and have the power it was meant to have. This may be a dumb question but to replace the cam you have to do what? because like we talked about im going to leave the motor in the frame could i still replace the cam? Or would i have to remove the motor to do so?
When you take the timing cover off, and take the timing sprocket off, there are 2 bolts that hold the cam in you will take them out, and there is a bearing there, it should slide right out. you can do it once you get the head off since it has to be removed anyways, one note here, make sure you don't drop the timing chain. you'll end up with a mess if it comes off the bottom sprocket.
