Smoking banshee
Smoking banshee
My banshee is smoking out of the right side pipe. its a white smoke with no real odor. I have replaced the head gasket cleaned the pipes and repacked the silencer and it still smokes. I have also cleaned the carbs and checked the reeds for damage. could it be possible that the head is cracked or damaged?
your help would be greatly appreciated.
thanks
thanks
Smoking banshee
yes, I was losing coolent. and smoking. thats why I replaced the head gasket, I've been kicking myself though for not checking the head when I took it off to change the gasket. before the quad was smoking I had it ported and milled the head and re-arked the domes. Is it possible that the head could have been weakend when the work was dome to it?
Smoking banshee
R&B racing did the work. they had an auction on ebay for port work. They did a great job on the port work. I also sent them the head to be milled and redomed and I think they may have messed up the head. I dont like to bad mouth anyones work unless Im possitive they messed it up. So I dont know if it was bad work they did on the head. I think I'll just buy a Noss head with 20mm domes and be done with it. I think that will be the easiest and best fix. Any pros or Cons?
Thanks for everyones help
