Warrior - No Spark
Warrior - No Spark
I put a different (ebay) motor in my warrior since the old one's case got cracked. I'm trying to get it to spark with no results. When swapping the motor out, the only thing for the electronics that was kept from the new motor was the flywheel. I changed teh stator right from the start since the plug on the replacement motor wouldn't fit my existing wiring harness. With others' help, I also swapped over the old flywheel to the new motor but I still can't get any spark. Any ideas on what to try or where to begin to trouble shoot it? It seems to have all the ignition parts of the old motor that was starting fine. Any help is appreciated.
Warrior - No Spark
check voltages, see where you lost power...if you got power from the stator, then that's not the problem, electrical **** SUCKS b/c it's a long process, you just need to go through it all and find where you loose power, it is possible that your CDI box went bad, or even your ignition coil*? not sure of the name, anyways, good luck bud.
