Yamaha Warrior: oil in air box
You sure that it's not oil from the foam air filter? The stock air filter on the Warrior has a foam element around the mesh filter that should be coated with oil to help it collect dust. If you look under the air box, you should actually see a clear cap that collects any oil that may drain off of the filter.
Yamaha Warrior: oil in air box"></title><script src=
<div class="FTQUOTE"><begin quote>Originally posted by: recon99
I've never seen oil in my airbox from riding up a hill... only time I ever saw it in the 4 years i've had my warrior was when it was just from over-oiling the filter.</end quote></div>
How much oil does the warrior take to fill when changing the oil ?
09-23-2015 06:23 AM
