Yamaha Blaster horrible bottom end
My friend has a 99 blaster, it has good compression due to recent rebuild. it has absolutely nothing at the bottom end, if you weigh more than 160 lbs, you would have to almost dump the clutch to move.... after inspected the reeds, there is a slight gap where the reeds should be flush. is this the whole problem?
he got the blaster for free. it was blown, and the jug was gouged up, so a friend of ours had the stuff that was used for 2 days before his bottom end went out and he just got a race motor. so all that was done was all the top end stuff from the donor motor onto this one (jug, piston) with a good bottom end. so we do not know how it ran before being rebuilt. the stock reeds were horrible so we took the reeds from that motor, which was sitting at a shop for a few months, they are boyeson dual stage, i guess they had got a little warped over time.
AN 03 RANCHER SHOULD ALWAYS OUTRUN A BLASTER. I HAVE RIDDEN 5 BLASTERS FOR OVER AN HOUR AND EVERYONE WAS SLOWER THAN A BAYOU, RANCHER, TIMBERWOLVE, THEY ARE HORRIBLE THATS WHY YOU CAN BUY A LATE 2000 MODEL FOR UNDER 1000 DOLLARS, THEY ARE HORRIBLE AGAIN GO 4 STROKE.
no the clutch is not slipping, and he has 18 inch tires on there to kind of compensate for the lack of power. its definitely in the motor, because it does this in neutral. you can feel the lag. and using the trusty butt dyno, it feels only like 10-12 hp at its best.
