stiff throttle cable
you probably need to lube the cable, spray the cable with cable lube and see what that does. to make the job easier you can buy the cable lube and the cable lube tool for about 12-14 bucks from rockymountainatv.com or if your near a cycle shop you can get it there.
when you lube your cables make sure you do it in 10 2 sec. intervals and keep doing it until you start to see the lube running out of the bottom of the cable. if it's comming out black or looks dirty keep doing it until it look clean and clear.
fordfaithful21
12-07-2015 05:52 PM
