How to jet My YFZ 450
Old 02-26-2008, 10:46 PM
YZF 450 MR's Avatar
Default How to jet My YFZ 450
I have no clue on how to jet my 450... I added an after market intake and i beleive its running a little lean now.. So i need to jet it.. But i have no clue, could someone tell me how to and give me a little education on how to do it and whats the best jets kits out there.... I have been reading about DIAL A JET but i dont understand how that works and what it takes to install it... please help me and point me in the right direction on how to jet my 450 ...
Old 02-26-2008, 10:53 PM
FordNut5's Avatar
I would recomend picking up a Clymer manual for your bike. They have lots of pictures and a pretty good step by step instructions. I'm not sure what size jets a 450 had stock but going up a size or two depending on your altitude should fix your problem if an intake is all you have added. I havent heard anything bad about a dial a jet. My understanding is that they work like a vacuum. Other than that dynajet makes a pretty good jet kit
Old 02-27-2008, 12:26 AM
cynick's Avatar
Dyno jet, Jets-r-us, FMF, just look in Rockymountain atv and pick one, they are easy to rejet, all you do is remove the drain screw in the bowl and your main jet is there. Besides, the kits usually come with instructions.
Old 02-27-2008, 12:47 AM
YZF 450 MR's Avatar
So when you your jetting your atv do you just have to change the main jet or what?? Or do you have to change anything else
Old 02-27-2008, 12:56 AM
beefy46172's Avatar
Loves To Ride!
Normally the main will suffice. You do have to adjust the e-clip on the needle to fine tune it, often times, though.
Old 02-27-2008, 01:47 PM
YZF 450 MR's Avatar
What is the E-Clip and how to do you adjust it
Old 02-27-2008, 03:49 PM
Hebs's Avatar
It's the clip on the needle...
Old 02-28-2008, 12:06 AM
YZF 450 MR's Avatar
So whats the risk if you dont adjust the clip.. could i just change the main jet?
Old 02-28-2008, 12:48 AM
beefy46172's Avatar
Loves To Ride!
You could, but there is no guarantee it will be as finely tuned as it could be. Sometimes adjust that clip can make a world of difference in hitting the perfect A/F ratio.
Old 02-28-2008, 10:55 AM
Hebs's Avatar
adjusting the clip is really easy... There was a video out a few years back... I'll see if I can find it... Maybe I'll post it on youtube if I can... It shows how to re-jet your yfz without taking the carb off... (basically loosen the hoses and rotate it a quarter turn. This gives you access to the bottom.) Makes it real easy... I forget who did it... They made a bunch of neat yfz maint. videos. I don't know if I still have them or not...
you could also look here
