Hotcam for raptor
Old 03-08-2008, 06:18 PM
ich4bdm's Avatar
Default Hotcam for raptor
How much difference will stage 2 hotcam make for my raptor.
Old 03-10-2008, 06:44 PM
ich4bdm's Avatar
not to much i guess
Old 03-10-2008, 07:29 PM
ATV24/7's Avatar
I dont know, but they say stage two is better if you have an aftermarket piston with more compression.
Old 03-10-2008, 08:05 PM
dewey_700r's Avatar
do you have to have stage one before you get stage two??? or can you go ahead and just get stage 2
Old 03-11-2008, 01:07 AM
Raptor450's Avatar
http://www.hotcamsinc.com/inde...ts.view&productid=530e The stage 3 would make an awesome cam for the 660 if you had at least a high compression piston. Stage 1 would be a waste of time and money IMO. The stage 2 would be OK for a stock engine and should make a noticeable difference, but don't expect to blow anybody's doors off with just the cam by itself. You can go ahead and get a stage 2 or 3 without getting a stage 1. The stages are how they determine the size of the cam, 1 being smaller and 3 being larger. You can read the specs of each on the link. Lift and duration is the important #'s. Lift is how far the cam will open the valves, and duration is how long it will keep the valves open. The further and longer they are open, the more power you will make. But if your stock piston and crank doesn't have enough *** and you install a cam that is too big and open the valves too far for too long, then you could lose a lot of bottom end power.
Old 03-11-2008, 02:32 PM
dewey_700r's Avatar
ok lets say i get a stage 2 cam what else can i do to add more power and speed
Old 03-12-2008, 10:13 PM
skramblr's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: dewey_700r
ok lets say i get a stage 2 cam what else can i do to add more power and speed</end quote></div>
Well, that depends. What mods you you have already? Intake, exhaust and engine mods?
Old 03-12-2008, 10:30 PM
Raptor450's Avatar
Get a high compression piston and the stage 3 cam, and an aftermarket air filter.
Old 03-13-2008, 08:02 PM
maddog56's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Raptor450
Get a high compression piston and the stage 3 cam, and an aftermarket air filter.</end quote></div>
Stage 3 is overkill without a decent port job.
Old 03-13-2008, 08:06 PM
dewey_700r's Avatar
i see i think im gonna go with the stage 2 cams, wiseco piston, comedic gaskets, and the motoworks full exhaust system
Quick Reply: Hotcam for raptor
