Max speed = 40 MPH
Old 03-10-2008, 04:24 PM
Forrest1's Avatar
Default Max speed = 40 MPH
Here is a little background of the bike specs and what I have done already.
2003 Kodiak 400 4x4
25" 12.5x12 Bear Claws on the back.
25" 8x12 Bear Claws on the front.
Big Gun exhaust
2000# Superwinch
I have cleaned and redressed the air filter with K&N recharging kit.
Cleaned and regreased the out sheave and clutch weights.
The belt is brand new
New battery - (only because the old one was dead)
So my question is, is this the fastest this quad will go given its current setup? A buddy of mine has an 05 400 and says he tops out just a little over 50 MPH and I have read other post stating the same.
Thanks,
Forrest
Old 03-10-2008, 04:43 PM
TLC's Avatar
TLC
TLC is offline
Somethings wrong, even my old 89 350 4x4 Big Bear could do 40mph easily. Your Kodiak has the 401cc motor right? Not the older air cooled 386cc Big Bear motor? Try Changing the belt, I was tied in top end with my cousin's 500 Scrambler but once he change the belt he could walk right pass me.
Old 03-10-2008, 04:48 PM
Forrest1's Avatar
The belt is brand new. The motor sounds strong and not like its slipping at anytime.
Old 03-10-2008, 04:56 PM
ss454's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Forrest1
The belt is brand new. The motor sounds strong and not like its slipping at anytime.</end quote></div>
Did you re-jet after putting on the pipe? I know my wolverine was lean from the factory and just pulling the spark arrestor and putting in a high flow filter leaned it way out.
Old 03-10-2008, 05:04 PM
Forrest1's Avatar
Well, you just about nailed my main question right on the head about the re-jetting after the pipe was put on. I bought this quad used and the pipe was already installed so I cant confirm if that was ever done. I have tried to do some research on this pipe and read in some posts that they state that no re-jetting is needed.
Old 03-10-2008, 05:38 PM
ss454's Avatar
Most ATVs are fairly lean from the factory and adding something like a pipe or high flow filter would make it even more lean.
Old 03-10-2008, 07:25 PM
Deviltrigger1's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: ss454
Most ATVs are fairly lean from the factory and adding something like a pipe or high flow filter would make it even more lean.</end quote></div>
Lean is bad or good?
Old 03-10-2008, 07:48 PM
ss454's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Deviltrigger1
Lean is bad or good?</end quote></div>
Lean means less fuel is getting to the motor than it should be.
Old 03-10-2008, 08:24 PM
Oh, ok
Old 03-10-2008, 10:18 PM
Mcgyver's Avatar
I have a 2003 Kodiak 400 2x4 I bought for my wife and bone stock it runs 48mph. When I first got it she only ran 40mph. I adjusted the valves and cleaned the carb out. Wow what a difference! You should try the same!
Quick Reply: Max speed = 40 MPH
