quad stalls when given gas
This isn't another problem with the Rev limiter on the park brake is it?
Release the park brake and try it again. Then, if that's not the issue, Try checking the circuit for the rev limiter and make sure it's working properly. Open when it's supposed to be, closed when it's supposed to be.
Most times I hear this description of symptoms,, It turns out to be someone forgot to release the park brake.
<div class="FTQUOTE"><begin quote>Originally posted by: Terrellster
Most times I hear this description of symptoms,, It turns out to be someone forgot to release the park brake.</end quote></div>
I was thinking this..But the other are possible too..Get rid of that stupid parking brake,It is Horrible for both Wolverines and Warriors..It is also a easy mod..
<div class="FTQUOTE"><begin quote>Originally posted by: viper5
The parking brake rev limiter shouldn't make the enging stall it just limited the engine speed and maked it not rev</end quote></div>
Mine will die if you stay in it while cold. Warm, it functions as you stated.
The OP seems like a new owner, and this is worth mentioning to a noob.
Frisky2050
04-09-2020 11:19 AM
