Wolverine 450 - top speed & dynojet ???
or too lean, you need to jack up the rear, run it wide open for 30 seconds, and shut the ignition off and bring the tires to a stop as quick as you can. then pull the plug and read it. there are alot of good places on the internet to help you read your spark plug.
That's possible too. Usually if your too lean you get sum backfire too rich it'll feel sluggish. Jetting is something I wouldn't have messed with unless you added a pipe and/or changed up filter or airbox. You won't have much, if any, performance change if any from solely a jet kit.
<div class="FTQUOTE"><begin quote>Originally posted by: Koopa
That's possible too. Usually if your too lean you get sum backfire too rich it'll feel sluggish. Jetting is something I wouldn't have messed with unless you added a pipe and/or changed up filter or airbox. You won't have much, if any, performance change if any from solely a jet kit.</end quote></div>
Exactly! Sounds like it's too rich. Just a hair lean is the best performance if I'm not mistaken.
