Raptor 660 bearings?
Need to replace the crank bearing on the right side(have a hot rod crank already) also need to replace the bearing for the counter balancer(on the right side), and bearing on right side case that is behind the clutch.
What i am wondering is can I get these bearings anywhere else besides yamaha? They seem kinda speny through Yamaha any help is greatly appreciated.
The rod broke and dropped off of the crank, somehow didn't damage the cyclinder in any way. The counter balancer was warped, as was the shift drum.
These bearings I have mentioned seem to have a little bit of drag when turning by hand, so I thought it would be best to replace while I am right there.
You can get bearings from somewhere else. They are usually the same bearing, just without Yamaha on them. We have a place here in town that specializes in bearings. They also rebuild electric motors, so if you have somewhere like that near you, you may want to check them out. Your old bearings have numbers on them, you will need these to match the new ones. I would be hesitant to install a different bearing on a crankshaft, that's an important bearing. You can start here http://www.bearingplace.com/
Alex Rodak
09-11-2015 11:42 PM
Elkaholic
09-06-2015 02:44 PM
