Raptor 700r suspension
Old 03-23-2008, 02:25 AM
toddmh's Avatar
Default Raptor 700r suspension
I have been looking at both and it seems the only thing they changed between 07 and 08 is the suspension,or am I missing something else??
The 08 has..[Front]Independent double wishbone w/piggy back High-/Lo-speed compression, rebound and threaded preload adjustment, 9.1-in travel
[rear]Cast aluminum swing arm w/rebound, High-/Lo-speed compression and threaded preload adjustment, 10.1-in travel
The 07 is..[Front]Independent double wishbone, 9.1" w/5-way preload adjustment
[rear]Cast aluminum swingarm, 10.1" w/rebound, compression and threaded preload adjustment
I'm asking because my local dealer has a 07 on sale for about $700.00 cheaper than the 08..Is that better suspension worth getting the 08??And what is Lo-Speed compression??is it like dual or triple rate sprigs or something??
Old 03-23-2008, 01:28 PM
Scooter86's Avatar
Knows Old ATV Questions!
Go for the '07 and save the 7 bones. You can get brand new take off shocks for under $250.00 and have the same thing there. The hi and lo speed compression adjusters let you fine tune how much compression the valving gives you. With the capability to change both you can make the shock softer for the smaller hits but firm it up a bit more for big jumps and such. It isn't the same thing as having dual or triple rate springs, but you do get some of the same effect.
bmxatv10
10-14-2022 06:23 PM
Robinhood
12-26-2015 10:28 AM
black_thunder
09-22-2015 07:59 PM
black_thunder
09-06-2015 04:41 PM
Quick Reply: Raptor 700r suspension
