I need help!!!!! with my Warrior
Old 03-27-2008, 04:51 PM
rkwhyte3's Avatar
Default I need help!!!!! with my Warrior
ok guys i need some help
even though how dumb this sound i had 2 jump my warrior and i hooked the jumper cables up and i did something i already replaced the battery and that didnt help so do u uys have any ideas........
please get bk 2 me...
thanks
kirby
Old 03-27-2008, 05:54 PM
TomM's Avatar
What exactly does and doesnt it do?
Does the motor spin but not start and run?
Does it spin slowly?
Not at all?
If you jump it again does it start?
Did you make sure your new battery has a good charge?
Connections clean and tight?
Checked all fuses?
Did it run good after you jumped it before?
Did it run good before you jumped it?
Old 03-28-2008, 12:07 AM
Raptor450's Avatar
The fuse under the left rear fender is probably blown. It is the round automotive style glass-type fuse in a rubber housing.
Old 03-28-2008, 12:14 AM
BANSHEE69R's Avatar
I HAVE FRIENDS WHO USED TO OWN WARRIORS. NEW OR USED EVENTUALLY ALL OF THEM ENDED UP WITH WIRING PROBLEMS DUE TO POOR DESIGN. YOU CHECK THE FUSES FIRST ALONG WITH CHECKING FOR CORRODED TERMINALS. THE NEXT STEP WOULD BE TAKING THE WRAP OFF THE WIRING HARNESS AND LOOKING FOR SPOTS WHERE THE WIRES BURNED THROUGH. THIS WAS THE PROBLEM ON MY BUDDIES BIKE.
Old 03-28-2008, 12:47 AM
Live4speed's Avatar
dont jump quads with cars!
Old 03-28-2008, 12:57 AM
Raptor450's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Live4speed
dont jump quads with cars!</end quote></div>
Why not?
Reactant
03-30-2022 02:08 AM
STLyamwar
07-25-2020 04:44 AM
Barnsnelbon
09-27-2015 03:07 AM
Bernhard
09-25-2015 12:45 PM
01ssls1
09-22-2015 06:50 AM
Quick Reply: I need help!!!!! with my Warrior
