Yamaha HElP ME PLEASE
Old 08-08-2008, 07:12 PM
polarispredator7678's Avatar
Default Yamaha HElP ME PLEASE
ok i have a blaster and i went riding and now it wont start its bogs down and dies i already changed spark plug andclean air filter do u think the pil injector could be blocked
Old 08-08-2008, 10:45 PM
Raptor450's Avatar
Check the reeds.
Old 08-08-2008, 11:52 PM
91Warrior357's Avatar
yea if its not the reeds then maybe ur bout time for a carb cleaning
Old 08-09-2008, 02:58 AM
hotblooded's Avatar
it is possible that you have an internal problem too. If you lost compression it may start for just a bit and then quit. Not sure how long it runs, you said that it wouldn't start. I had one with a broke ring and it would fire but after a short time bog and die. I would check the compression for sure if you think it is possible the oil injection is plugged.
Old 08-13-2008, 03:30 PM
Ok it has like no compression it wont start
Old 08-13-2008, 03:50 PM
blaster24's Avatar
Sounds like its time for a topend rebuild but its not to hard or expensive for a blaster even cheaper if you do it yourself!
Old 08-13-2008, 04:33 PM
hotblooded's Avatar
That is kinda what I figured. Did the motor ever lock up? if it did you need to take a look at the bottom of the motor to make sure that the engine case isn't broke. If it didn't lock up you probably just need to clean motor out and change the piston. The Blasters are noted for breaking the piston on the intake side of it. Like blaster24 said it isn't a huge job changing it, just when you do make sure that there are not pieces of the piston that are stuck in the rod bearing. I like to pull the motor out and wash it out with gas oil mixture after the cylinder is off. If you don't really know what you are doing I would recommend finding a local engine guy to do it for you. It wouldn't be that expensive to do. We change our piston on our race Blaster every 7 race days which is 14 races.
Old 08-13-2008, 04:35 PM
hotblooded's Avatar
I should add though, if you think that you have a problem with the oil injector make sure you fix that too. I personally get rid of the injection and premix the gas. That way you know for sure the oil is getting in there.
Old 08-16-2008, 04:50 PM
what do u mean did the engine lock up?
buddieboy
12-09-2016 05:50 PM
Barnsnelbon
09-27-2015 03:07 AM
Bernhard
09-25-2015 12:45 PM
jbrewster94
09-23-2015 04:16 PM
09-23-2015 06:23 AM
Quick Reply: Yamaha HElP ME PLEASE
