grizzly 700 will not start - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 09-12-2008, 10:26 PM
Default grizzly 700 will not start
gotta a 2007 grizzly 700 fi. having a problem with the starting. like it won't. have checked all the fuzes and even replaced the fuel system relay. nothing. when hittin the start button the engine light at the top right of the display flashes. any ideas cuz am freakin out
Old 09-13-2008, 07:18 AM
the display flashes? is the starter doing anything? it sounds like the battery may be low or have a bad connection. check and clean the connections and it it wont start, then try the next suggestion. you can connect it to a car battery with jumper cables to see if it will start. if that takes care of the problem, replace the battery.
Old 09-13-2008, 08:16 PM
If engine cranks but won't fire, remove the plug and check for spark, if no spark check ignition. If you got spark, check for fuel. If no fuel, check fuel pump for voltage to pump.
You haven't taken it swimming have you?. If you've sunk it, turn it up on end and drain the tailpipe, remove spark plug and crank it over to blow out the water in the cylinder then drain the oil to get water out of the lower crankcase. do this 4-5 times, along with the diffs. Don't forget the oil filter each time either, along with airbox.,
If you tried to crank it with water in the cylinder, you may have scored the rings, the cylinder, and the piston. Which means it's time for the repair shop.
Old 07-14-2011, 11:29 AM
How do you check for fuel if you find out you have spark? I think my atv is starving for fuel and that is why it is having problems
Old 07-14-2011, 12:09 PM
Before you do anything, get a repair manual for your machine, You don't want to break a bunch of stuff disassembling your bike. I would suspect wiring shorts,corrosion, or chafing to fuel pump, check these with a multitester. Pull plastics and check wiring. Next check voltage to fuel pump. Then, pull pump and filter assembly from your tank. Most new bikes have pump in tank now. Check pump pressure with pressure gauge. Replace fuel filter.
If all listed above checks out ok, then test fuel injector. Finally look at engine control module (ECM). It is the most expensive part, that's why I listed it last.
I know this is alot of work, but your labor is the cheapest labor you'll ever pay for.
Thread Thread Starter Forum Replies Last Post
What are these two ATVs $800 apart? TLC Yamaha 10 07-01-2015 08:29 AM
I think I got a deal? RPK Yamaha 6 06-08-2015 01:05 AM
Hello from SW Indiana atvdave Introduce Yourself 2 06-04-2015 06:06 PM
NOS-Atvs - Trail Scouting Extreme (Part 2) 1000gade ATV Videos 0 05-27-2015 12:37 PM
Rancher 350 S/ES or Grizzly 400? Undecided350 Buying an ATV 3 01-15-2001 03:55 AM
Tags
07 , 08 , 700 , check , fuel , grizzly , injection , pump , relay , spark , start , system , water , wont , yamaha
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
