Warrior with HMF slipon - what jet to use?
Old 04-03-2009, 01:17 PM
Swerve's Avatar
Thats true. I had forgotten that they had those. If you can get one with the clamp in style I would. I have the drop in style. I have never had any problems with it but it is kind of a crappy design. It's hard to get the little foam gasket to mash down into the slot with the filter.
Old 04-03-2009, 02:47 PM
Mud Junkie's Avatar
Thanks guys....
Where is a good place to buy the better K&N set up?
Old 04-03-2009, 04:16 PM
91Warrior357's Avatar
yea drop ins are crap, specially if you choose to run your bike with the lid off, because then the filter will just be sitting in there not fastened in at all, you need a kit like this
and when its installed it looks like this, which is way better its actually fastened direct
Old 04-05-2009, 05:58 PM
Mud Junkie's Avatar
Cool - thanks. I picked up 2 news jets for $5 at a local dealer. A 147.5 and a150. I found a place that sells the pro flow K&N kit for just under $100 so I am going to order that next. Once I have it on, I am going to rejet with the 147.5 first...if that's not enough, then I'll do the 150.
  #15
Old 07-28-2010, 12:20 PM
driftking's Avatar
does it matter what exhaust you use with the hmf jet kit???? i have an aftermarket exhaust on my 88 warrior and it has no brand plate on it what so ever. so im curious if it matters what exhaust i have any answers would be great
  #16
Old 07-28-2010, 09:42 PM
hmf jet kits are for their pipes, it might not match another pipes specs,most likey the pipe you have on your bike would be a DG or Cobra...pretty common on old warriors and they will be old with no nameplates, the pipes are really crappy in the first place, mine had a Cobra on it when i first got it, and switching from cobra to the HMF was a night and day difference in sound and power.
Reactant
03-30-2022 02:08 AM
STLyamwar
07-25-2020 04:44 AM
Barnsnelbon
09-27-2015 03:07 AM
Bernhard
09-25-2015 12:45 PM
01ssls1
09-22-2015 06:50 AM
Quick Reply: Warrior with HMF slipon - what jet to use?
