98 big bear lower ball joint
Old 09-12-2009, 01:04 PM
David222's Avatar
Default 98 big bear lower ball joint
I am in need of some help. I have found a bad ball joint on my atv. 98 big bear 350. Can you replace just the joint press out/ cut out? or do you have to replace the whole a arm. Recommendations for a good parts supplier would be appreciated.
Thanks
David
Old 09-12-2009, 02:36 PM
91Warrior357's Avatar
im pretty sure that the ball joints arent removable, there whole a-arm and ball joint is one piece which sucks, idno if a machine shop could do anything with it or not, usually you have to get new a-arms off ebay or something.
Old 10-26-2012, 11:33 AM
soproblemas's Avatar
Hi David! Im having the same problem. Can you tell me how do fixed? Do you buy a arm or just a ball joint?
thanks
Old 10-26-2012, 11:48 AM
TLC's Avatar
TLC
TLC is offline
Yes that sucks the way they make it one piece. This place sell the A arm for $85. upper and $88 lower.
Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old 10-26-2012, 02:40 PM
ShelbyGT660's Avatar
I know mine is a different machine, but I am pretty sure they offer ball joints for the timberwolf, Why would they offer em on a cheaper machine and not on a more expensive machine?
Old 10-27-2012, 04:24 AM
yes its a bit stupid!
Old 07-15-2016, 07:16 PM
electrical 01's Avatar
Default easy my friend remove from the A arm and adapt from grizzly
Ok my friend remove from a arm and adapt by soldering one from grizzly that comes apart, not the whole arm
Thanks
David
Old 07-15-2016, 07:19 PM
Default cut the piece
Need to cut the piece to remove
Thanks
David
exmotocrosser
09-13-2019 06:12 AM
wendal
10-04-2015 03:18 AM
Quadzilla Heritage
09-25-2015 01:39 PM
jbrewster94
09-23-2015 04:16 PM
89Lt250r
09-07-2015 07:53 PM
Quick Reply: 98 big bear lower ball joint
