1988 yamaha big bear 350
alright, not sure if this is the right area. but im looking to get a yamaha big bear 350
now as you can see, its pretty old. is there anything generally wrong with these ? thye look pretty solid but the age kinda "urks" me i guess, only thing wrong with it is, the recoil broke off and needs a battery, other then that he says the engine is perfect ,
any help would be awesome thanks
Leaky engine output shaft oil seals are difficult to fix. Front prop shaft splines and universal joints can fail, and the splines on the rear axle, where it goes through the diff can fail. All these faults occur after high mileages so don't be put off, but check a used bike for them before you buy.
