1987 Big Bear stuck in 4th gear
Trans
Before this started happening--when you shifted into reverse and then back out of reverse did it go back into the gear you were in or did it start back in first gear? I would agree with 6666...adjust the clutch tensioner and see what that does for you...seems to be a more complex than mine...I have no high/low...only five speeds rather than 10...you may look on partshark.com and see if you can find a free service manual for that model...wish I could give you more help I know it is frustrating to have stuff that doesn't work like it is supposed to...Good Luck.
Mudslinger2
Mudslinger2
The atv in question is not mine, it belongs to a friend and I'm trying to help him. I also own the same atv, same year. Adjusting (loosening) the clutch sounds like a place to start, I know exactly where you mean. Thanks for your help. I will post back with results.
micheleLeigh
Technical and How-To Articles
07-19-2015 07:32 AM
KimSJoh
14
07-18-2015 07:20 PM
