VIN anyone??
not sure exactly on your model, but most VINs are either on the left part of the frame under the engine, on the vertical run of the frame heading up towards the handlebars, or on the very front of the frame just under the plastic in between the headlights. hope this helps. most of the time they're stamped into the metal frame, probably gotta clean it good and you should see it. should be a 17 digit alpha-numeric sequence.
