Yamaha Warrior 350 Intake boot?
I put a new intake boot on my warrior not even 2 years ago and it looks to be going bad already. Has anyone else had this problem? The old one I took off was broken in half. This one I put on was brand new it has cracking on it already. It is not broken but looks like it is on its way. What do you think? Thx
Check to make sure you have mounted the intake tube correctly, it has a slight angle to it, and if put in backwards, will put strain on the rubber mid section and engine vibration can cause early failure, I've had mine on my Wolverine since 95 (same motor/carb as you) with no problems. There is a little arrow cast into the rubber, it should point up as you look at it from the left side of the machine. The flanges will bolt up either way, so it would not be hard to get it wrong, but the extra angle could put strain on when you tighten everything down and put the carb/airbox boot on, which would have to pull it down slightly to line up,flexing the middle rubber part.
OEM or aftermarket.
I had the same issue a couple years back when replacing an orriginal boot on my sled, now the 2 year old aftermarket one looks like its shot already.
