1999 big bear will not start
I have a 1999 big bear 350. I can pull crank it but can not use the starter. I have replaced ther relay and the fuses. The netural light come on when the key is turned and the starter will turn if jumped across the relay. I tries jumping the push button and that did not work either. I have just about ran out of ideas and not sure if I am missing somthing simple. If anyone can help it would be great or if any one has a wire diagram or knows where I can get one that would help also. Thanks in advance.
having a spare solenoid is not a bad idea. that could be a hidden blessing if your original fails out in the wooded trail and your ripcord gets broken.!
