Just picked up a 2001 Yamaha Blaster - Have questions
DONT JUST THROW ANY OIL IN THE TRANS ON A BLASTER!!! It must be ATV or motorcycle specific oil or oil that is "wet clutch compatible" or "contains no friction modifiers".... Reason being the blaster uses a wet clutch. Meaning that clutch is lubricated with the transmission oil. If you use an oil that is not compatible with a wet clutch then your clutch will slip. If you want more details check out the link in my signature. I have a TON of how to vids. Some are on the banshee but most apply to any two stroke ATV.
Pete
I just ordered new Boyseen reeds, air filter, spark plug, new Scott grips, FMF Gold Series Fatty pipe/silencer and oil injector blockoff kit.
I'm hoping to install all these parts this weekend. I'd also like to replace the factory wheels and tires so would anyone know where I can get a nice package deal? How are the Douglas aluminum wheels?
Thank you,
Pete
Thank you,
Pete
Thank you,
Pete
Thank you,
Pete
Rockymountainatv.com has aweseom wheel/tire combos and I believe they even come mounted if you order as a package deal!
#16
Thanks guys!
I finally had the chance to install the exahust, silencer, new spark plug and air filter last week. It sounds much different than stock, but I like the sound.
I haven't jetted the carburetor yet but will need to order the FMF power up kit. Hopefully it will give me a noticable power difference. My better half will be riding the blaster.
Pete
Pete
#17
Frisky2050
04-09-2020 11:19 AM
toonces
10-16-2019 12:11 PM
