700 Grizzly ATV
Well,its fuel injected, so not a jetting problem....lol. I would check the basics, make sure the air filter is clean, you may have a dirty/sticky clutch that causes it to bog at first and then it moves and take the load off the motor, I would start with the filter, then once you are sure the air box is clean and the fuel is good, take a look at the clutch, may need a good cleaning/regreasing,or maybe even a new belt, depending on miles/wear and tear.
TLC
Utility ATVs
09-16-2015 01:41 PM
