86 4-Zinger carb problems, need help
I am working on a 86 4-zinger 60 quad, my problem is that after running and shutting it off after about 15 mins it leaks fuel out of the carb drain hose and also will take fuel in the airbox. I have removed the carb, completely cleaned the carb, the float is in plastic float, it is not cracked or taking in fuel, I replaced the needle, I cleaned the seat where the rubber tip of the needle seats and I still have fuel coming out the back of the carb going into the airbox and draining out of the drain after about 15 mins after shutting off. The quad runs awsome but this problem is really starting to be a pain. Any help or info would be greatly appreciated. thanks. Dan
