96 yfm80 badger starting problems.. Valves?
Hello,
This is my first time in these forums and boy am I glad to find them! I recently purchased a 96 badger that I plan on giving to my daughter for christmas.
now the problem:
When the guy brought it to my house he had to crank the starter for about 3-4 minutes before it would start. Once it had run it would fire right up every time. If i let it cool down it would be very hard to start once again. I have adjusted the valves @ .004 intake and .005 exhaust. this did not change how it starts. I have fuel, air, and spark. WHAT AM I MISSING?
Thank you for your help.
now the problem:
Hello,
now the problem:
now the problem:
Nothing special in those areas on my part.... but you could also check and clean the air filter.... All kinds of stuff could slow the start-up. Those being the most likely. (poorly adjusted coil pick-up for the ignition could cause hard start also..... bad ground somewhere (Usually at the battery).... keep on diggin'
I have a copy of a manual in digital format if the OP can accept a large PDF file.... I'll need a place to send it....
Hankey Pankey
26
10-18-2020 03:50 PM
TegraQuad
1) Engine problems..
13
11-26-2017 01:40 PM
