450 kodiak (IRS) U-JOINTS
Old 11-18-2011, 10:23 AM
painman's Avatar
Default 450 kodiak (IRS) U-JOINTS
Does anyone know or has replaced the rear u-joints on the IRS, I just need to know if it is nessary to remove all the rear end to achive the R&R or can you take the 4-bolts out of the dif. and just slide it back far enough to slide the U-joint out.
Hope I have made myself clear enough so you know whatI am trying to achive.
Thanks for your time;
Old 11-18-2011, 05:02 PM
painman's Avatar
Default U joints
Just for those who might care; I did the repair myself, not fun but it is done. So all you have to do is take of the C clips and remove the old caps, requires a little hammer and a punch.
Then take the drive shaft to the vice and knock out the rest of the caps, then just a little tap to get the new u joint in.
good luck ;
Old 11-22-2011, 06:53 PM
CraZySteve's Avatar
good luck ;
Sounds like you go it
You can remove the 2 bolts that hold the rear diff to the frame - that will allow you to seperated the splined drive shaft. And then procede as you stated.
Also if you want - shoot me an email I have a present for ya I know Xmas is next month.. but I do have the 03-06 kodiak 450 service manual....
snowwmax@yahoo.com
YankeeRebel
10-06-2015 06:44 AM
RedRancher
08-10-2015 01:28 PM
07-28-2015 12:12 PM
RedRancher
07-10-2015 06:36 PM
Quick Reply: 450 kodiak (IRS) U-JOINTS
