How does motor oil get to the driveshaft boot?
I am losing my motor oil. It goes straight into the boot that surrounds the driveshaft. Would this be a rear seal issue? I don't see how it could get from the engine to the driveshaft area. Maybe I'm wrong, but it seems like this is what its doing. Thanx in advance for your help.
RandyD
RandyD
Sorry about that...........2000 Yamaha Kodiak 400 4x4.....Here's the major issue that I am facing, perhaps some of it will make sense to you, as it sure doesn't to me! Thank you in advance. Randy D.
http://forums.atvconnection.com/yama...x4-2001-a.html
Where is it exactly leaking if you look at the middle drive gear break down you will see a o-ring that seals the outer part to the motor is it leaking around this or is it leaking from the seal that goes on the yoke if its that seal make sure to check for a groove in the yoke where the seal rides as they tend to make a groove and then the seal looses tension on it to retain the oil.
I haven't torn it down, got too much mandatory over time this week.........my workday starts at 4:30 AM and I don't get home til after 7:00 pm, sometimes as late as 10.....That's why I want as much information as I can get, ahead of time, so I know what to pay special attention to.
Thank you very much EPI Shawn for your help. Anyone else, please chime in.
Thank you, RD
