yamaha big bear oil temp light...
The following users liked this post:
Jenny Williams (04-05-2021)
you can not use a led bulb in the oil temp light , old school only!
Good day , just a reminder that you can not use a led bulb in the oil temp light i a 1988 Big Bear (or older models ), as needs the resistance from the bulb to complete the circuit. If you have an oil temp light that stays on check the bulb , mine was a led , works correctly with old style bulb installed .
I am still using EverBright BA9S 1893 Led Bulbs for the reverse and neutral lights with no issues , just can not use them with the oil temp light (circuit ) , old school bulb only.
[img]data:image/svg+xml,%3csvg xmlns='http://www.w3.org/2000/svg' xmlns:xlink='http://www.w3.org/1999/xlink' viewBox='0 0 16 16'%3e%3cdefs%3e%3clinearGradient id='a' x1='50%25' x2='50%25' y1='0%25' y2='100%25'%3e%3cstop offset='0%25' stop-color='%2318AFFF'/%3e%3cstop offset='100%25' stop-color='%230062DF'/%3e%3c/linearGradient%3e%3cfilter id='c' width='118.8%25' height='118.8%25' x='-9.4%25' y='-9.4%25' filterUnits='objectBoundingBox'%3e%3cfeGaussianBlu r in='SourceAlpha' result='shadowBlurInner1' stdDeviation='1'/%3e%3cfeOffset dy='-1' in='shadowBlurInner1' result='shadowOffsetInner1'/%3e%3cfeComposite in='shadowOffsetInner1' in2='SourceAlpha' k2='-1' k3='1' operator='arithmetic' result='shadowInnerInner1'/%3e%3cfeColorMatrix in='shadowInnerInner1' values='0 0 0 0 0 0 0 0 0 0.299356041 0 0 0 0 0.681187726 0 0 0 0.3495684 0'/%3e%3c/filter%3e%3cpath id='b' d='M8 0a8 8 0 00-8 8 8 8 0 1016 0 8 8 0 00-8-8z'/%3e%3c/defs%3e%3cg fill='none'%3e%3cuse fill='url(%23a)' xlink:href='%23b'/%3e%3cuse fill='black' filter='url(%23c)' xlink:href='%23b'/%3e%3cpath fill='white' d='M12.162 7.338c.176.123.338.245.338.674 0 .43-.229.604-.474.725a.73.73 0 01.089.546c-.077.344-.392.611-.672.69.121.194.159.385.015.62-.185.295-.346.407-1.058.407H7.5c-.988 0-1.5-.546-1.5-1V7.665c0-1.23 1.467-2.275 1.467-3.13L7.361 3.47c-.005-.065.008-.224.058-.27.08-.079.301-.2.635-.2.218 0 .363.041.534.123.581.277.732.978.732 1.542 0 .271-.414 1.083-.47 1.364 0 0 .867-.192 1.879-.199 1.061-.006 1.749.19 1.749.842 0 .261-.219.523-.316.666zM3.6 7h.8a.6.6 0 01.6.6v3.8a.6.6 0 01-.6.6h-.8a.6.6 0 01-.6-.6V7.6a.6.6 0 01.6-.6z'/%3e%3c/g%3e%3c/svg%3e[/img]
[img]data:image/svg+xml,%3csvg xmlns='http://www.w3.org/2000/svg' xmlns:xlink='http://www.w3.org/1999/xlink' viewBox='0 0 16 16'%3e%3cdefs%3e%3clinearGradient id='a' x1='50%25' x2='50%25' y1='0%25' y2='100%25'%3e%3cstop offset='0%25' stop-color='%23FF6680'/%3e%3cstop offset='100%25' stop-color='%23E61739'/%3e%3c/linearGradient%3e%3cfilter id='c' width='118.8%25' height='118.8%25' x='-9.4%25' y='-9.4%25' filterUnits='objectBoundingBox'%3e%3cfeGaussianBlu r in='SourceAlpha' result='shadowBlurInner1' stdDeviation='1'/%3e%3cfeOffset dy='-1' in='shadowBlurInner1' result='shadowOffsetInner1'/%3e%3cfeComposite in='shadowOffsetInner1' in2='SourceAlpha' k2='-1' k3='1' operator='arithmetic' result='shadowInnerInner1'/%3e%3cfeColorMatrix in='shadowInnerInner1' values='0 0 0 0 0.710144928 0 0 0 0 0 0 0 0 0 0.117780134 0 0 0 0.349786932 0'/%3e%3c/filter%3e%3cpath id='b' d='M8 0a8 8 0 100 16A8 8 0 008 0z'/%3e%3c/defs%3e%3cg fill='none'%3e%3cuse fill='url(%23a)' xlink:href='%23b'/%3e%3cuse fill='black' filter='url(%23c)' xlink:href='%23b'/%3e%3cpath fill='white' d='M10.473 4C8.275 4 8 5.824 8 5.824S7.726 4 5.528 4c-2.114 0-2.73 2.222-2.472 3.41C3.736 10.55 8 12.75 8 12.75s4.265-2.2 4.945-5.34c.257-1.188-.36-3.41-2.472-3.41'/%3e%3c/g%3e%3c/svg%3e[/img]
1010
Facebook Post
1010
