99 bear tracker
99 bear tracker
Hi all, i have a 1999 bear tracker that has very low hours on it. I got it about two months ago, did normal maintenance on it. I ride it every week at least one day a week, last week didnt have the chance. So yesterday i go and start it, put choke on etc and she starts up, then i walked in the house and came out it was off. Thought maybe it was still cold, so i tried again to realize it just cranks and dosent want to turn over. I pulled the spark plug out and dont see a spark. Anyone else ever have this problem. CDI BOX, capacitor what could it be, also does anyone know where i can get the ohm readings so i can check to see what isnt getting the right about of juice??
Thanks guys
Thanks guys
maybe found the problem
so today i tested the pick up coil today and found out that the reading was at 0 and the source coil readings were up to specs. I also checked the kill switch and that tests out ok also. I should say me friend who is a boat mecanic did it. He knows what hes doing. So i guess its the pick up coil correct?
Thanks
Thanks
exmotocrosser
09-13-2019 06:12 AM
Elkaholic
09-06-2015 02:44 PM
