Rear Brake Removal on a 2000 Big Bear 400
Old 03-28-2012, 12:40 PM
Nltocean's Avatar
Not a problem .... I'll inbox you my regular messenger if that will help!!
Old 03-28-2012, 05:06 PM
bowanna03's Avatar
I removed the bracket and cables and moved the spline back and forth ans this thing will not come off
Old 03-28-2012, 05:16 PM
Nltocean's Avatar
when the Bracket was ON ... did you try to twist it?? Or pull it up n Down??
Old 03-28-2012, 07:41 PM
bowanna03's Avatar
I first want to thank Nltocean as she has been more than helpful. NO good news though... I broke the drum as it was literally rusted to the shaft. New problem is I can't get the remaining pieces and the base of the hub off. I will attach pictures also. Sorry I cant post pictures...
  #15
Old 04-11-2017, 10:14 PM
Jr Wagner's Avatar
Default Help
How can I remove the wheel hub I took off the axle nut. An trying hitting it with a hammer nothing I need help so I can check the back brakes
toonces
10-16-2019 12:11 PM
AK47KID
07-23-2015 09:21 PM
scaldwellk
06-19-2015 05:08 PM
UPLou
06-07-2015 09:42 AM
Quick Reply: Rear Brake Removal on a 2000 Big Bear 400
