Banshee carb HELP
Banshee carb HELP
So i recently put dual 35mm mikuni carbs on my banshee. and im have problems with it cutting out and it will not idle at all. the guy i bought the carbs from said i would only need to change out the main jet. He suggested a 200 main jet. But now i cant get it to idle and it doesnt run worth a sh****************. any suggestions would greatly help. i would rather do the work myself then take it to a shop. I have full pro circuit exhaust and i took the snorkel off my airbox
Stock Mikuni have around a 260 main. I had a 290 in my Banshee when it had stock cly's with Toomey pipes and K/N filter. I have a port job and 4mil long rod motor in it now and run 310 mains. The 200 you have in there seem to small to me. I have a set of 34mm Mikuni's I'm going to install and will start with 320 mains.
07-07-2015 11:00 PM
