timberwolf slow return to idle
Old 10-16-2012, 08:21 PM
yamahatimberwolf's Avatar
Default timberwolf slow return to idle
i got a yamaha timberwolf i just recently bought. been sitting for a while, so i decided to rebuild the carb. rebuilt it, installed and it started right up. it will idle pretty smooth but only thing is that it is slow to idle. It will rev up and then instead of instantly going back to idle, its takes like 7 or 8 seconds. Any idea what could be causing this? any help is appreciated
Old 10-17-2012, 03:07 PM
Cummins Driver's Avatar
I had this issue with my big bear. I fixed the problem by richening the air/fuel screw(counterclockwise), and lowering the idle as I went. Go out a turn, adjust the idle down and see if it helped. If so keep going till its right. It is a frustrating problem because there is no engine braking when it hangs off idle. Lol. Let me know if this helps.
Old 10-18-2012, 01:03 PM
thanks for reply. i adjusted the fuel/air mixture screw and it idled down a lot better. I also noticed the boot that ran from carburetor to air filter box was loose, i tightened it and it made a big difference. Thanks again.
2quiker
03-22-2022 08:36 PM
fordfaithful21
12-07-2015 05:52 PM
spark1051
Utility ATVs
09-04-2015 07:58 PM
sleepyva
09-02-2015 06:32 PM
Quick Reply: timberwolf slow return to idle
