99 warrior 350 problems
IF the float is stuck, the gas will just keep flowing into the carb with no way of it stopping. I'd assume the warrior has an overflow (not sure) but it could be stopped up. This would cause the gas to just flood into the carb and back out of the air intake. As was mentioned by jswald you might want to check the oil too. It is sometimes possible for the gas to get into the oil. If that happens and it doesn't blow a seal it will wash the cylinder and the oil wont lube correctly and good bye piston and cylinder.
This is a very common problem hince the fuel cutoff switch for when it is not in use. (prevents it from happening)
I think stock size main jets on a 99 warrior is a 145. Don't quote me on that, but to see if it has been jetted (or attempted to be jetted) you could pull the main jet and see if it is larger. If so, the previous owner changed the mains out.
Without a doubt, its always best to check the plug to see if you are rich or lean. I'd rather be a bit rich than lean. Easier for me to deal with a little bogging and get that right than a rebuild cause of a lean condition.
I cleaned the float and carb put everything.back together rode the bike for about 10mins came.home let it idle then i heard a dripping sound. This time it was comming the the flow tube..so does that mean i gotta tear it apart and clean it.again or should i just bring it to the.shop and let them.deal with it.
