2003 kodiak 450
2003 kodiak 450
I have a 2003 Kodiak 450, there is backfire sometimes when you go from full throttle to no throttle, it is the original carb and exhaust, the only thing is the muffler can almost seems empty. does anybody know if it has a baffle inside or its just an open can, also I don't have the tip of the exhaust (spark guard), would that make a difference? I bought it a few months ago runs great except for the odd backfire.
THANKS
THANKS
I would say this may be normal especially if your hard on the throttle and basically letting it snap to the idle position. When you do so, the carb is only allowing fuel to the cylinder via the idle circuit even thought the engine is still at high revs. This along with the fact that you have shut the throttle plate creates a lean mixture which does not get combusted completely in the cylinder. As the unburned gas/air mix leaves the cylinder it builds up in the exhaust system and ignites there creating a backfire.
Try easing off after hard throttle and see if it helps. I know it may not be your style!
I've an 05 450 and I can't help you on your second problem. Actually I think you had it figured out in your original post with the bad muffler and no end plate. Letting off accelerater with no back pressure will also cause it to back fire. On the carb are you sure you got all the old gasket out or does the bowl have a side that goes to the front etc. . Anyway after bending it your going to have to get the specs and reset it. Good luck.
Impalaman
1) Engine problems..
12
11-08-2015 07:17 AM
greg86hd
09-16-2015 12:32 AM
