Raptor 660 wont move please help
Ok been sick for awhile and just now getting over it had flu and amonia but i just picked up a raptor 660 guy said it just stopped moving and needed a clutch well it runs awesome and it shifts gears but wont move if you put it into a gear and pull clutch in motor idles up when u let go of clutch motor idles down like its grabbing the gears but isnt moving im new to the 4 stroke side of it all could anyone tell me what i need to start checking or good starting point without takeing it apart right away would like to ride it soon
The most common thing wrong would be the clutch plates need replacing. It could be the transmission, but I would check the clutch 1st. I put Curtis Sparks clutches in my 660 when I had it, but Barnett makes kits, as well as others. You will have to drain the oil. Take the clutch cover off the right side of the engine, remove the clutch plates,examine them and make sure they are to specs. Hopefully they won't be, anything else could cost you! Make sure you use the correct oil for wet clutches (Yamalube or equiv) and soak the new clutch plates in that oil for a while before installing them. I'm sure there are detailed instructions on the web somewhere on exactly how to do it.
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
