07 Grizzly 125 shuts down shortly after startup
Wondering if anyone has an idea of why my kids grizzly might be shutting off. It will start up and idle no problem and if you can get it gear and start riding full speed it won't give any trouble as long as you dont let off for a few minutes. If you baby it then it will cut off as the idle drops. But if you start it and let it idle it will shut down after about 5 minutes and wont start back up unless you spray carb cleaner in the intake tube and even then it wants to give trouble starting. It turns over fine and will spit like it wants to start but wont stay running on its own.
It seems like maybe it is burning the fuel in the line but then shuts down after it burns that off. If I get it restarted and running off of carb cleaner then it will run all day long no problems. I can let it idle as long as I want to and it wont shut off either. But the next time I try to start it I get the same problem.
Any idea as to what may cause this?
OutRacing
Technical and How-To Articles
09-03-2015 07:49 AM
