2004 Big Bear Hitch?
Old 03-01-2013, 08:34 PM
pokerjokerau's Avatar
Default 2004 Big Bear Hitch?
NEWBIE!!!! Will a 2004 Big Bear take a trailer hitch? I am wanting to buy one to possibly till/disc up land in addition to riding. Just curious if the 2004 Big Bear 2x4 can have attachments hooked to it. Thanks for any help!!!
Old 03-02-2013, 09:03 AM
oldmattb's Avatar
A little confused by your question. My 2003 has a hitch that is part of the rear axle housing. Does your Big Bear have independent rear suspension? I thought that was a 2005 and up thing. My manual lists pulling capacity of 904 pound-feet, and tongue weight of 33 pound-feet.
Hope this helps.
Matt B
PS Mine's 4WD
Last edited by oldmattb; 03-02-2013 at 09:24 AM. Reason: pre-coffee cogitating is dangerous
Old 03-02-2013, 10:54 AM
TLC's Avatar
TLC
TLC is offline
You buy a ball 1-7/8 or 2" for $10 and put it on. Never heard of a Big Bear with no place to mount a ball already on it.
Must be a straight axle if its a 2004. Never seen a utility ATV of any kind that did not have a trailer hitch from the factory.
Thats odd only 904lbs towing rating, the smaller 350 Grizzly/Bruin has a belt and no low range and is rated for 1,102 lbs. http://www.yamaha-motor.com/outdoor/...0/0/specs.aspx
Old 03-02-2013, 01:38 PM
Actually it turns out the big bear is a 2000 and yea it has a hole right on it to put a hitch ball. Thanks guys!
Old 03-02-2013, 07:05 PM
oldmattb's Avatar
NO excuses! Get to work!
Matt B
Old 03-02-2013, 07:24 PM
Connor Schuster's Avatar
i have a big bear and i added a hitch to to take a 2 inch reciever and the hitch is a 3 way with a hook, ball, and a hole to put a pin for trailers
exmotocrosser
09-13-2019 06:12 AM
exmotocrosser
09-26-2015 08:18 AM
Bernhard
09-25-2015 12:45 PM
Sw00p
09-24-2015 02:50 PM
jbrewster94
09-23-2015 04:16 PM
Quick Reply: 2004 Big Bear Hitch?
