97 yamaha wolverine
97 yamaha wolverine
I have a 97 yamaha wolverine 350 4x4 when its on idle it miss fires and seems like air is comming out of the head but does'nt have white smoke comming out of it and also when its in neutral and i gave it full throttle it cuts of and also does it when im in frist gear but once it gets warmed up it does'nt miss fire and the spark plug seems to be good anyone have any idea on whats going on?
No didnt check that just asking how would that effect it miss firing like that? But i got a better look at it and there is a small hole in in the carb boot and there is air comming out of that i think thats the problem thats making it miss fire but still dont know why it wants to shut off when i give it gas it seems like its not getting enough gas but i had the crab ajusted
the carb boot could be causing all of your problems it will have the incorrect a/f mixture. Go to an autoparts store and pick up some rtv gasket sealant and put that on the hole and see if the problem goes away. I'd do a carb kit while I had it off if it was me.
The RTV likely wont last all that long but it will at least tell you it fixes the problem. those boots are pretty expensive, around 200 bucks!
