97 timberwolf 250 4x4 head gasket need help
Old 04-22-2013, 09:49 AM
abadbowtie's Avatar
Default 97 timberwolf 250 4x4 head gasket need help
I have a 97 Timberwolf 250 the head gasket is leaking between the block and the head I have a complete head gasket set that I need to get this pulled apart tonight and put back together. I have grass need to be cutting I'm not sure if there's a howto and a list of all the torque specs.
thanks in advance
Old 04-24-2013, 02:42 PM
abadbowtie's Avatar
Well I did get it all apart the other night and had to order one head bolt I messed up the threads on it. One of the 10" long bolts I messed up the threads pulling it out it comes all the way out other than the last 2" and hits something in the whole I spun it out with wrench but wiped off the threads not sure why. I think the bolt is hitting were the doll rod goes thru for the rocker arm or something like that. It is the bolt sitting on the quad front left bolt that I messed up. I do have bolts coming hopefully will have them tomorrow or friday but still need to see if I can find a how to to make sure I get this all back togther correctly. I also need torque specs.
1ArmBandit
55
10-14-2015 09:03 PM
tysonbully
09-28-2015 02:30 AM
Quadzilla Heritage
09-25-2015 01:39 PM
09-23-2015 06:23 AM
Quick Reply: 97 timberwolf 250 4x4 head gasket need help
