07 Raptor 350 clutch issues
Old 05-06-2013, 04:01 PM
kellenb11's Avatar
Default 07 Raptor 350 clutch issues
My raptor starts great and idles great as well but when i shift into first gear the engine revs fine but the clutch is slipping or something and when i start to go it just doesn't have much power. You might be thinking the clutch is burnt up but after like 5 mins of riding i get all the power back. Every time i start it cold it does this please help!
Old 05-17-2013, 10:07 PM
mmb's Avatar
mmb
mmb is offline
Still might be the clutch, after 5 minutes the oil gets warm and helps with the clutch, or might be the oil your using, also make sure the clutch cable releases fully on the crankcase.
Old 05-18-2013, 06:44 AM
kellenb11's Avatar
I dont think that the oil is the issue considering im using yamalube but you might be on ti something with the clutch cable but I dont know how to fix it or to tell if it is not fully realeasing.
Old 05-18-2013, 10:43 AM
mmb's Avatar
mmb
mmb is offline
Check that you have free play on the clutch handle, usually 1-2 mm but check the manual for exact. Also inspect the clutch cable releasing, I'm pretty sure it is on or near the top of the crankcase in the raptor 350. I have a warrior and I'm pretty sure the engine is the same.
Old 05-21-2013, 09:18 PM
kellenb11's Avatar
I checked and it looks fine Ill just bring it in to a shop and let them deal with it, hopefully its an easy fix. Thanks for the advice
brad wheeler
07-13-2015 11:19 PM
Dirtbikemike1
Technical and How-To Articles
10
07-12-2015 07:22 PM
Dirtbikemike1
07-11-2015 03:36 PM
black_thunder
07-09-2015 05:58 PM
Dirtbikemike1
07-09-2015 01:27 AM
Quick Reply: 07 Raptor 350 clutch issues
