125 Breeze starter problems
Old 05-27-2013, 10:28 AM
wk2fish's Avatar
Default 125 Breeze starter problems
We have a 2001 breeze. A while back we had problems with it not starting when it was hot. I did a search on here and from the info I found I replaced the one way bearing and that seemed to fix it. It has been a few months and now I am having the same problem again. Anyone have any ideas as to what else may be causing the problem? Thanks
Old 06-05-2013, 12:13 PM
Doctorturbo's Avatar
GOT BOOST!
Hope you saved the "good" springs out of the old one way because it maybe just a spring or two bad again. 99.9999999999% of the time it's just the springs. If you can find a spring source you can just replace them for just a few bucks.
Old 06-24-2013, 04:02 PM
wk2fish's Avatar
Still having the same problem. I changed the filter on the intake up front where it draws air for cooling thinking it may be getting to hot still no good. The old bearing got thrown away by mistake.Has anyone ever just replaced the springs and exactly how does the one way bearing work? Thanks
skinnyr6
08-25-2023 02:18 AM
Sjrpp
11-15-2019 09:59 PM
Sjrpp
06-02-2019 07:25 AM
KimSJoh
14
07-18-2015 07:20 PM
tweeder
07-05-2015 01:57 PM
Quick Reply: 125 Breeze starter problems
