Yfz Running hot?
Yfz Running hot?
Hey, I just picked up a 2007 Yfz 450 right off the show room floor. It has a K & N air filter on it and the exhaust is super hot. Is this normal? I heard that the Yfz's were known to run to lean off the floor, and with the filter and allowing more air in, I guess it's running even leaner?
Yep, the air filter will make it run more lean, the YFZ450's exhaust are hot anyway. It may be a good idea to do a jet pass and if the results show a too lean condition, jet it a little richer. My buddy always complained about how hot his was, it was always burning through his pants leg. I measured his exhaust pipe where your leg rides with my laser thermometer at over 700 degrees, and as far as I know it was jetted properly! For comparison I measured the exhaust on my Warrior at 400 degrees.
Frisky2050
04-09-2020 11:19 AM
TegraQuad
1) Engine problems..
13
11-26-2017 01:40 PM
bzdok1234
30
02-23-2016 01:55 PM
