2007 big bear 400 no 4wd...
Old 07-17-2013, 07:32 PM
bonesk78's Avatar
Default 2007 big bear 400 no 4wd...
Bought a used bike a few days ago knowing that it wouldnt go into 4wd. I thought it would be an easy fix by replacing the servo motor. Here goes...
I first checked all fuses...good.
I put 2 c batteries on the front servo. Servo motor works.
I checked 1 relay. Bad. Replaced relay. Still no 4wd.
I checked other 2 relays. Good.
No 4wd.
What next?
Old 07-17-2013, 08:12 PM
TLC's Avatar
TLC
TLC is offline
Old 07-17-2013, 08:58 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
How about the actual switch at the handlebar?
Old 07-18-2013, 10:40 AM
bonesk78's Avatar
Originally Posted by TLC
Checking the motor with 2 c batteries confirms the motor is good.
Old 07-18-2013, 10:45 AM
bonesk78's Avatar
I took apart the buttons on the handle bar. All connections appeared in good condition, nothing frayed, pulled apart. The manual says refer to checking the switch, but then all it does is tell you where it is. There was no checking procedure indicated.
The green light by the key is always on. So that tells m something has to be incorrect. I will continue today.
Old 07-19-2013, 10:05 AM
bonesk78's Avatar
Replaced the 5 relays in the back. The light on the dash is off. The atv is now in 4wd with differential locked. Will not unlock or go out of 4wd.
Old 07-26-2013, 08:24 PM
4getful2's Avatar
Check the servo, to make sure it is back in proper and disengaging
exmotocrosser
09-13-2019 06:12 AM
jbrewster94
09-23-2015 04:16 PM
09-23-2015 06:23 AM
braap123
09-07-2015 12:58 PM
braap123
09-07-2015 10:57 AM
Quick Reply: 2007 big bear 400 no 4wd...
