01 beartracker problem
Old 07-18-2013, 10:44 PM
charpie's Avatar
Default 01 beartracker problem
my beartracker ran for about 1 min and died so far I've checked spark,put fresh fuel in,checked timing,cleaned the carb ,primed it,all this happened after replacing the battery with a smaller one it,s still 12 volts it,s new just for a smaller machine.it idled for 1min then died like it just was shut off not a pop after. this is the first time I've ever seen anything like this . everything looks good
Old 07-19-2013, 09:29 PM
Raptor450's Avatar
I suspect you're not getting fuel? Pour a few drops in the sparkplug hole, reinstall the plug and then see if it cranks. If it does, then you're not getting fuel through the carb or not getting fuel to the carb. If that's the case, it could be a stopped up pilot jet, stopped up float needle/seat, or a stopped up fuel petcock.
the only other thing you haven't mentioned is checking compression, but 4 stroke motors usually don't lose compression that easily.
Old 07-19-2013, 10:35 PM
charpie's Avatar
thanks for the reply I cleaned the carb ,replaced the fuel, and primed it a few times I also tried the choke until it ran out the carb replaced the plug. the compression I'm not sure if I cracked a ring my compression tester don't fit the small plug hole but I tried putting my finger over the hole and cranked it leaked around no matter how hard I tried to seal it. and when I use the rewind it feels good.im really stumped. unless the muffler is pluged I didn't check that
Old 07-20-2013, 11:59 AM
Raptor450's Avatar
What's it mean to "prime" it?
Old 07-21-2013, 04:22 PM
charpie's Avatar
I poured some fuel in the carb a few times and poured some fuel in the plug hole a few times. not a pop i'm thinking compression
Old 07-21-2013, 09:00 PM
charpie's Avatar
found the problem pull started it and it was running lean. there was a small crack in the carb boot so I put a patch on it until I get a new one.running good now thanks for the help
Old 07-22-2013, 06:26 PM
Raptor450's Avatar
Cool!
greg74
09-10-2019 03:03 PM
ogio117
Polaris Side by Sides
04-29-2019 03:14 PM
ScopeZ_
07-28-2015 01:44 AM
Ty64
Technical and How-To Articles
07-25-2015 02:02 PM
hondarider1234
07-21-2015 11:53 PM
Quick Reply: 01 beartracker problem
