1988 warrior with clogged carb
Old 09-22-2013, 07:34 AM
Diesel Grinch's Avatar
Default 1988 warrior with clogged carb
Trying to figure out how to clean out the carb. Right where the gas comes in it's clogged. Can't blow in or suck out. I worried to use an air compresser and try it. Any ideas on how to clean it out?
Old 09-22-2013, 08:58 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Yes, remove the carb from the machine. Take the float bowl off (bottom of carb).
Remove the float, and both jets and clean all well.
Old 09-22-2013, 06:24 PM
That did it. Was able to pull it out and clean it up. Thanks
Old 10-05-2013, 06:33 PM
andy jones's Avatar
yea ccarb cleaner and compressed air is the best stuff to uses for that sort of stuff but to prevent just stick a fuel filter in the fuel line to prevent again as it could if you have any crap left in ur tank all the best
Reactant
03-30-2022 02:08 AM
GregM
03-06-2018 06:53 AM
Aitch
07-21-2015 09:40 PM
Reactant
07-16-2015 10:29 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
07-08-2015 02:16 PM
Quick Reply: 1988 warrior with clogged carb
