could use alitle help with my 02 660r
Bike has been running great. Piped it out. Jetted and cold air box..today i rolled it and ate some serious dirt. After i rolled it back ovsr i let it sit a min. Now when i ride it back fires like crazy and boggs down at half throttle. Also the back brake light is blinking when i hit the throttle. Kinda stumped. Any suggestions. Thanks guy
The backfiring could be you messed up your parking brake sensor on the clutch perch, it has 2 wires going to it. If it's still there I would just bypass it anyway. If I remember right, you have to tie the wires together to make it run correctly. Same thing with your brake light, there is a light sensor at the foot pedal and at the handlebar lever for the front brakes, there are 2 wires going to each sensor and something is shorting out, I would bet it's on the handlebars.
Thanks guys for the imput. The bike took a hell of a tumble and yes the air filter is clean...lol. its somethinh more. Gonna look into that sensor. Think i might have knocked the carbs out of sync. This is my first 4 stroke so all kinda new. Im a 2 stroke man. Love my 250r,s. Is it hard to sync the carbs. Again thanks guys any bit of info helps. The dealership wants alot of money to look ay it. I figures if i can build cars i can handle this. Lol
Also make sure the carb didn't come loose from the intake boot, that was a problem on the earlier 660's. I wouldn't think you would need to "sync" your carbs, they should have already been setup properly before the tumble with the correct jetting. I don't think the 2 carbs are as sensitive as the Banshee was.
