Electrical Issues 95 Wolverine
I have searched a bit on here and can't find my problem. My wolverine was not starting consistently. It would take about 10 presses on the start button. Nothing would happen and then suddenly it would start. Figured it was either the starter or the solenoid. I took off the relay/solenoid and on the bench found it to do the same thing. So I figured it was a bad relay. I kept trying to find a new relay but could not. One day I tried bridging across the relay connections with a screwdriver and saw a big spark but it did not start. Was that bad?
So I threw the old relay back on and the neutral light, oil light would not come on at all. I finally found a new relay and put the new relay in and the lights still don't come on.
Seems like I blew a fuse somewhere but I don't know where to look besides on the relay.
Any suggestions?
Any suggestions?
OK. I worked on it again tonight. When I turn on the ignition the oil and neutral light do NOT come on. And the start button does nothing. However, I bridged across the solenoid/relay with a big piece of copper wire and it started right up. Again, none of the oil, neutral lights show up. The ignition was on and when I turned it off the engine shut off. Somewhere in the ignition has got to be a blown fuse or something. The fuse on the relay/solenoid is OK. Anywhere else to look? And what do they look like?
get volt meter an check conunity both direction if reading both ways or open aalso check it may have diode in relay I cant remember if read one way an not the other diode in relay. when you are crossing over solenoid you are bypassing soleniod you are putting the 2 big wire into one wire an sending power straight to starter an thats why it work that way
